alex019 avatar image
alex019 asked
Victron Multiplus-II 48/8000 3Phase?
Is it possible to switch a Victron Multiplus-II 48/8000 in 3 phase? (3x Victron Multiplus-II 48/8000)
for the 3000 and 5000 models this is possible, but for the 8000 I can't find the right info.
Multiplus-II
markus avatar image
markus answered ·
Yes, it is indeed possible to build 3 phase systems with the 8k and 10k MP2 units.
It is not possible (yet) to use the 8k and 10k in parallel systems, where there is more than one unit per phase.
BR
alex019 answered ·
From a product specialist, (Question posed by email to Victon support) (Stroomwinkel.nl)
I got the following answer:
(Answer in Dutch below)
Dear Alex
Unfortunately, you cannot use the 8 and 10k in parallel or in 3 phase.
Victron has opted for a certain internal structure (hardware), which unfortunately means that this is not possible.
We as Stroomwinkel also hope that this will become possible in the future.
However, you can use the old familiar Quattro type for 3 phase or parallel operation.
If you have any questions, we would like to hear from you.
Beste Alex
De 8 en 10k kun je helaas niet parallel of in 3 fase gebruiken.
Victron heeft gekozen voor een bepaalde opbouw intern (hardware) waardoor dit helaas niet mogelijk is.
Wij als Stroomwinkel hopen ook dat dit in de toekomst mogelijk wordt.
Wel kun je het oude vertrouwde type Quattro gebruiken voor 3 fase of parallelle werking.
Zijn er nog vragen dan horen wij dit graag van u.
Unfortunately, it is not yet clear to me whether the Multiplus-II 48/8000 can be put in 3 phase.
Is there anyone who has official documentation on this that can clarify this?
The datasheet says:
VE.Bus communication port:
For parallel (not for 8k and 10k models) and three phase operation, remote monitoring and system integration.
For me that means three phase is possible but parallel not.
alex019 answered ·
I inquired again via email.
Now I got the following response from a System Engineer:
Best,
I just checked with Victron:
At the moment the 3-Phase function is not a problem, this is possible.
Parallel is not possible at the moment, but should be possible in the future.
This corresponds to your answers.
3 phase for the Multiplus-II 48/8000 is therefore possible.
Parallel switching not yet.
Thanks for your input.
iand avatar image
iand answered ·
Just be careful about "parallel should be possible in the future" -- it's not clear whether this means "possible with MP-II as sold today by updating firmware" or "possible with future MP-II hardware revision". Victron need to say which is the case, the difference is crucial for anyone buying an MP-II today who might want to add parallel units in future.
shaneyake avatar image shaneyake commented ·
As far as I have been told from Victron, Needs a hardware change but is in the works. We were told not to order 8 and 10k if we plan to parallel till this update has been made.
Yes it is a hardware limitation and it will never work with the currently sold 8k and 10k MP-II.
iand avatar image iand Matthias Lange - DE ♦ commented ·
Thanks for making this clear. Suggest you also make sure that other Victron support staff do the same if asked the same question, to avoid any confusion and possibly annoyed customers ;-)
