piemuth avatar image
piemuth asked
115v and 230v as Input for multiplus
I will try in english:
We need to use 110v (north-america) and 230v (Most of the world) to feed our 24/3000 Multiplus in our vehicle.
Can I use an Isolation Transformer 3600 (Auto) to use These both voltage without changing any wire for both cases?
I was told this is not working but in the specs I can read, that this transformstor can be just for 115-230 / 115-115 / 230/115 and 230-230V
We only need 115-230 and 230-230....
Or is there any better solution?
Thank you,
Piet
Ps: Second question: what is the different between a Multiplus and a Multigrip for our use in the car?
Multiplus-IIIsolation Tranformer
Johannes Boonstra (Victron Energy Staff) avatar image
Johannes Boonstra (Victron Energy Staff) answered ·
I was indeed talking about the Isolation Transformator 3600 Auto
The auto-isolation transformer is a good option. You need only to set the board voltage (with a jumper ) during installation and from then the transformer will converter automaticly up/down if it needs to. PS the frequency on board will follow the incoming frequency!
piemuth avatar image piemuth commented ·
Johannes, thanks for you answer.
I have to ask: Do you speak from the "Isolation Transformator 3600 Auto"
ITR050362041 ?? That is the product I was thinking from.
or do you mean the "Autotransformator 32A" ITR000100001
I think the "Isolation Transformator 3600 Auto" is the better one....
