jcottis avatar image
jcottis asked
Multiplus II not showing AC Input on Cerbo error message AC-Input: Not available
Just connected my new Mutiplus-II 24/3000 to my Cerbo today however I am not sure why I am getting the error "AC-Input: Not available" and it also registered an alarm, any assistance appreciated.
Multiplus-II
thechad avatar image
thechad answered ·
I figured it out, at least in my situation... I needed to go into Menu > Settings > System Setup and set both AC inputs to Shore Power.img-4202.png
Additionally, I installed the release candidate firmware (2.80~17 ) and it now shows both line 1 and line 2...
scottd avatar image scottd commented ·
Thanks this fixed my issue also.
thechad answered ·
I have this same issue! Multiplus II + GerboGX My dashboard looks almost identical.
With the Bluetooth dongle connected to the MPiII (with the CerboGX disconnected), I can see all of the AC details in and out for both line 1 and line 2. So, it's not like the MPII doesn't have this data.
Have you found a resolution? I have tried replacing the data (ethernet) cable also...
I also have an MK3-USB I will connect in a bit to see what it sees and tweak a few settings. Maybe there's a bit to flip in there somewhere that might help...
-chad
wbogan avatar image
wbogan answered ·
@TheChad, I had the exact same problem and your fix solved my issue as well. I was checking every option on the Multiplus and this got to the right screen in the Cerbo GX. Thanks so much. I also love your channel on YouTube. Keep up the great work.
