magicmike avatar image
magicmike asked
EasySolar/ Multiplus 48/3000 Power generator issues.
I would like to ask if this is normal that after i have generator connected bulbs on my inverter every 60sec changes from;
'Charger: Mains ON/ Bulk ' to 'Inverter: Inverter On'
I would like to ask someone to correct me as well if my configuration is not correct.
I cannot upload file so i give link;
https://easyupload.io/eqjbld
I would like to set up generator to start when batteries hits 50/55% so it can charge bats a bit.
EDIT:
SOLVED/ UPS MODE AS MANUAL SAID IN MY CASE MUST BE OFF. WEAK AC OPTION HELPS AS WELL
Generator
basil katakuzinos avatar image
basil katakuzinos answered ·
Try turning off UPS function and see if the result improves
magicmike avatar image magicmike commented ·
Looks like it runs only under 'weak ac' mode :)
and yes- UPS function must be off.
For other people who run into the same "problem" it is not good to delete the question.
I will recover your original post.
