ifraser avatar image
ifraser asked
Old victron Pallas manual?
Hi all. I have a boat from 1997 with a Victron charger that is marked as a Pallas 12v 50a. I have searched high and low and cannot find a manual. I want to adjust the equalization and float voltage but not sure which potentiometer is which. I can find a manual for a Pallas TG 12/50 but that appears totally different from what is inside our charger. I did once find a manual for an old inverter charger, I believe it was a Titan and the charger bit appeared close to what we have but I cannot find this manual again. Our Pallas charger has 4 tiny potentiometers in two groups of two on the top of the circuit board that is fixed to the opening front panel. Any help gratefully received. Many thanks.
charger
ifraser avatar image ifraser commented ·
Hi Matthias, thanks for your help. Trouble is I already found the page you link to and the Pallas chargers there are not the same as mine. I appreciate that sounds a bit daft but there are no DIP switches in my charger just tiny potentiometers. The only 12/50 listed is a the TG so I'm wondering if there is an even older Pallas that wasnt denoted TG?? I did once find a manual relating to an old inverter charger that I thought was a Titan but I can't find this again now. It does seem odd that the manual for a Pallas 12/50 does not line up with my Pallas which is a 12v 50a but it doesn't so I can only guess its a really old model? My guess is it is original to the boat which is 1997 but that is just my guess...Thanks for your input anyway :-)
Matthias Lange - DE avatar image Matthias Lange - DE ♦ ifraser commented ·
I the manual of the 12/25 is something about potentiometers.
Maybe that helps you.
Chargers.
