jokani avatar image
jokani asked
Multiplus voltage & temp sense wires
Do I need to connect/install the Multiplus voltage sense & temp wires if I have a SmartShunt fitted?
I'm presuming the SmartShunt will report the voltage & temp, and distribute via Ve. Bus. and the Multiplus would get the info this way?
Multiplus-II
klim8skeptic avatar image
klim8skeptic answered ·
If you have a GX device, the multi can use the Smart Shunts voltage and temp data.
Please refer to the CCGX manual, and brush up on DVCC.
jokani avatar image
jokani answered ·
Bump, please help.
jokani avatar image
jokani answered ·
Will do, ta for the advice, I did not think I need to connect the extra cables, but wanted confirmation from an expert. Thanks.
The SmartShunt don't have a VE.Bus and the MultiPlus don't have VE.direct.
So they can't communicate with each other. You need a GX device for that.
