judd-1 avatar image
judd-1 asked
Hi All, I have recently installed a 5 Kva, 10Kwh solar system and this weekend the low battery light on the inverter kept illuminating. there was 2 voltage drops but battery is back up to 98 %. any idea why...
Multiplus-II
5 comments
You measured the battery voltage?
And you fully charged each battery before you put them in series?
judd-1 avatar image judd-1 klim8skeptic ♦ commented ·
Yes i have and the voltage is good but this low battery light still flickers
klim8skeptic avatar image klim8skeptic ♦ judd-1 commented ·
Perhaps check the battery voltage at the Multiplus input terminals.
Just in case of a bad connection.
Paul B avatar image Paul B judd-1 commented ·
Have you checked the Voltage at the multiplus WHEN THE Multiuplus is under LOAD. And what type and size is your battery bank
@Judd@switchenergy
Did you upgrade the battery cables to handle the extra amperage draw?
