blackdragon avatar image
blackdragon asked
help with connecting with Battery monitor BMX-712 Smart for the first time
I try setting up but i don't know if i did it correctly. I connect one on the battery terminal to the battery shunt then one on the negative 100/50 MPPT solar charge Controller. next I connect power cable to the battery postitve then B1 terminal. then next RJ12 UTP cable head to the RJ12 terminal shunt. Is that all? oh can someone show me their display in detail please.
BMV Battery Monitor
