Hy I have a lithium titanate battery. it is a 6S with a maximum voltage of 16,8V
In the product discription of victron parts is stated that the maximum imput voltage is 17V
can I for instance use the phoenix 1600 inverter on that voltage safely or is the voltage to high for the electronics. the inverter is the only part I need to use on the battery directly in regard with the current the inverter uses to give 1600 watt
