james-owens avatar image
james-owens asked
Ip22 charge current adjustability
Can I adjust the output current of an ip22 12v 30A(1) to less than 30 amps via app? I need the 30A to charge a 100ah battery but also have a 24ah battery for a fish finder. I hope to get away with one charger rather than buying a 10 A charger for the smaller battery. Thanks in advance.
bluesmart ip22
av1um avatar image
av1um answered ·
hey there!
pls DONT charge the battery (assuming both are lead-acid?) with 30A. this is way too much for the battery. you could set the IP22 to "Night-mode", which will then reduce the output only 7,5A (for 8 hours) - but for the 24Ah battery even this is way too high.
