Hi: I screwed up. When setting up my Venus GX I was connecting via the built-in WiFi access point. I was about to set up the connection to my home WiFi and I accidentally turned off the “Create Access Point”. Now I can’t see the GX’s built in WiFi network. How do I turn this back on?
Do you mean the Victron Venus GX device. If so there is a button you can press to reset the network settings. See Section 8.4 of the manual.
Brilliant. Thank you so much. I’ll be trying this out in a A few hours.
