Last year i used my cement mixer to mix heavy concrete and it was somewhat over loaded, this for particularly noticed when tipping the drum horizontal to empty into a wheel burrow. I have a MultiPlus-II 10kva system and the cement mixer is 230v single phase induction motor.
Last year I nearly stalled the drum, it really struggled when horizontal. I mentioned this in this forum and I was advised to upgrade the multiplus firmware which I did do after the cement job. Although I couldn’t for the life of me figure out how firmware could improve the MultiPlus-II with induction motors.
Fast forward to this weekend, ive been putting off a concrete floor job, and thought I have to get it done, dreading the cement mixer problems, but I decided to push ahead and mix the concrete, I over loaded it again (I cant help myself than to make big mixes) and I was expecting the stalling problems when tipping the drum into the burrow, but this time it worked flawlessly, as if it was running from grid power (im off grid) and I got the job done with zero issues.
Here’s my question, what has this firmware update done to the way the MultiPlus-II can now drive an induction motor? I always thought a 50hz sinewave is a 50hz sinewave, how can an update change this?
