SOC display on ccgx
My system is not displaying soc on color control after updating the firmware to 2610556. What might be the problem?
I assume you mean you updated the inverter to firmware 556. Did you reload any settings and sometimes firmware updates can over ride the settings with default values and you have to reload them. I suggest you look at your settings on the inverter and see if the battery monitor settings have been lost. As you are on VRM you can download the settings file and if you have VE Configure on a pc/ Laptop then you can edit the settings and upload them back to the inverter. If you updated the firmware over VRM then there is a specific process to follow. Many people mis out step 3.3 in the link below and do not re-instate their settings.
Well appreciated. The system worked well
