SOC disappeared from dashboard
Although my system is working fine and I’m running the lastest VenusOS firmware v3.54 some day the State of Charge (SOC) graph disappeared from the VRM dashboard:
(I mean the thin blue line in the ‘Installation data’ diagram)
But the correct SOC is present and the diagram is shown in the ‘Advanced’ section:
Any ideas what I can try to get it back?
Thanx, Ralf
Do you see the square with battery behind it under the graph? Click on that and it will return.
Also, your forecasted consumption is off to, click on that square too to get it back in the graph.
Wow, life can be so easy…
Thanx a lot!
Sometimes it can be indeed!
You’re very welcome!
Except when it can’t:
Transient bug? Missing since today. No battery square.
