Shelly 3EM-63W and Shelly 3EM-63T supported?
Is the Shelly 3EM-63W and Shelly 3EM-63T supported?
anyone?
Do see the pro 3EM is supported, but what about 3EM-63W and 3EM-63T?
And in case phase phase 1 and 3 is switched on the 3EM-63T version, can I switch these in software?
3EM-63 is just the general model, while the suffix T describes the type that uses protruding flat terminals to measure the voltage directly on the MCB/relay terminals it is connected to, while the W suffiy is the type that uses wires to measure the voltage on some other location, like the MCB input.
None are switched. They are simply measuring/monitoring devices. The measure current by passing a wire through, while the voltage measurement has the two connection options.
Also just in general, no Shelly meter can be used as a grid meter for a Victron ESS, at least not natively with just the Shelly integration
As grid meter I use an EM540.
Would like to measure the consumption of mine heat pump, can I do this with a shelly 3EM-63?
Yes, I have the 3EM-63T that measures my electric boiler.
And this directly works?
Or do you need to install some drivers?
  1. Connect to Wi-Fi via the Shelly app on the same network as Victron.
  2. In the Victron remote console, go to Shelly integration and turn it on there. Under devices, set it as the heat pump.
Thanks!
Going to order one
I had some issues a while back with the Shelly for the heat pump and running it in the Victron system.
How are things now — have the issues been resolved? I still have it installed, but I haven’t activated it again yet.
