Shelly Pro3EM - native integration of MultiPlus II as an energy meter
Hello everyone,
How can I integrate the Shelly Pro3EM as a meter for the ESS?
So far, I have integrated the Shelly via a start script, which works very well. However, because of the native support, I now wanted to switch over with firmware 3.79. I can also find the Shelly via the IP search, and it appears under “Devices”, but what do I do now? If I disable the start script, I have no way of forwarding the native Shelly to the ESS. Or is there something that needs to be configured on the Shelly?
Shelly cannot be used as grid meters for ESS. At least not currently with the native integration. Maybe that will change, maybe it won’t.
Venus OS v3.70 - Shelly support:
V3.70 beta - new Shelly support:
Please use the forum search; the topic, including all the pros and cons, has already been discussed in great detail.
There’s a good reason why Victron doesn’t support Shelly devices as grid meters.
Why not just stick with the startup script? It works brilliantly, doesn’t it?
I have several installations running like that without any problems.
Thanks!
I had already searched, and the Pro3EM was explicitly mentioned there. The limitation that it doesn’t work as a grid meter wasn’t mentioned.
Never mind, I’ll stick with the startup script, since it works exactly as I need it to.
