Hi, I have quite simple question, which (although Im an installer) I dont know the answer to. The realtime data in VRM dashboard on my personal installation stopped showing. It sometimes shows updated “a few seconds ago” or “1 minute ago”, but since yesterday it doesnt show “realtime”. The old GUI works, but the new GUI stopped working too. I tried restarting cerbo (softwarewise and also disconnecting power), restarting modem and switches, restarting ve bus (no idea why, but I have tried), checking enabled realtime data in VRM setup, updating to the last Venus version…but no luck with solving the issue. I think the whole issue started with one of the power outlets in the house which I accidentally shortcircuited during one experimental setup and caused blackout in the whole house for a while. Maybe it is just coincidence because everything else works normally now (except the realtime VRM dashboard and new GUI). The VRM id is c0619ab3c277 (just in case someone from Victron would be kind enough to look into it…). Does anyone have any idea what could be the cause of this? Thank you for your answers…
Hi, no stored records. And in my case cerbo is actually connected to the internet with ethernet port, so that should be ok…
I recall reading at some point that if the Cerbo processor load is high that it will stop realtime updates to reduce cpu load. I think it may do the same if the internet connection is found to be too slow. Has your power problem affected your router.
Found the bit re cpu load. May be an issue with systems running Node-RED, modifications or third party add ons.
Does your network have any firewall restrictions? GUI-V2 requires some different data ports open for TCP / UDP traffic than does GUI-V1. I have one client’s site where some packets are intercepted by a firewall, and GUI2 does not work (yet). I also had some problems on my own site accessing GUI2 on LAN, when the internet went down for a few days.
I would add that I have seen a few systems with this fault—we install SD cards on everything we ship, and just ejecting the SD card will make it live. I wonder if there’s perhaps a file corruption problem with the database.
I have a card installed too. I found that if I change (inc/dec) the IP address of the Ethernet port it will reconnect to VRM.
Thank you all for your tips. It seems that eventually the problem somehow solved itself and yesterday I suddenly started seeing realtime data again. However, the real reason why it happened is still unknown for me.
I got same problem and tried many things, but the reason was stupidly easy.
VRM site → Settings → General → Realtime updates green(on) / red(off), mine was set to off…
I have seen quite a lot that the VRM app on my mobile phone does not update for a long time, and when I use a webbrowser to see the VRM portal, I get realtime data.
I emphasis, this not a problem i’ve seen once, but have this seen this more than often.
But… I think what the probable cause is.
And, in my case, the problem is not the VRM portal…
I have a Samsung phone A54 5G, and those models (and maybe some others as well) have a “WiFi problem” as I call it.
Online you can find many complains that this model (maybe others too) have “strange WiFi problems”.
This is the strange behavior:
WiFi is set to on.
When I use an app (e.g. for whether forecast) most of the time it does not work (95 out of 100), sometimes the app works after a very long waiting time 10 or more minutes.
If I, at the same time as the above problem appears, I go to a webbrowser, like firefox, and open a website (still connected via WiFi) I get immediately response/data.
So my WiFi does work, but the first app appears not to have access to WiFi, while the other app -at the same time- can use the Wifi connection.
Now, if I go back to to the app that seems not to be working, than I turn WiFi (than automatically my phone switches over to 3G/4G/5G), the weather app does work correctly! (so there you have the prove that the problem was the WiFi connection).
I have noticed this behavior with several apps (newspaper, VRM, different weather apps).
So it seems that there are two pathways (two types of API’s) to the Wifi functionality in my phone.
Some apps use WiFi connection method #1, and others (like firefox) do use WiFi connection method #2.
So my recommendation is, if you have no real time data in the VRM app, try to switch off WiFi and see if this helps. You can also use VRM via a webbrowser.
I have the same issue. After reboot the CERBO it works for a couple of days, but real time data feature gets lost again. The only thing i changed in den cerbo is that i am using the modbus interface for reading some data from the cerbo.
Any fix for this?
Another issue connected to this issue is: You loosing the update feature for the devices. The buttons are missing on the vrm device side. After a reboot the buttons are there again. This is a screenshot of my device list, if you do not see real data in dashboard.
There should be two buttons below the device list but they are missing if real time data is not working.
Many functions, including updating, require a realtime connection.
Are you on a wired or wireless connection?
A weak or intermittent wifi signal can cause issues like this.
You can also set the cerbo to auto reboot on comms loss to VRM.
I am on a wired gigabit lan connection.
Cerbo is on version 3.72
Hmmm. i have found a setting for this auto reboot. Is it this setting? (Sorry my gui is in german. hope you can translate it by yourself.
Last time it worked for two or three weeks after a reboot.
Can i reboot the cerbo on a running installation with 3 multi plus and an mppt without any issues?
That’s the one.
With a wired connection there is no chance of interference.
Reboots are fine, system will just go into passthrough while it is restarting.
I watched the timer which shows the last connection. It goes up to 1 min, then it seems to get a connection again and the timer starts from 0.
By “passthrough” you mean AC in is passthrough to AC Out?
Mppt’s will power down, loads will be supplied by mains or battery.
After a reboot the device list looks like it should: (Also take a note of the Gateway icon. It changed)
Also the real time data is working again.
So i realy don’t know why this stopped after some days. I think it will stopp working in a couple of days again.
The gui tells me to fix orange issues on page “support state”
But what should i fix? This Modbus TCP Sever is from victron. I am using this to read data from an EM24
There is also a strange button which says: Click, to update to v3.72.
But the cerbo is already on v3.72. What does this mean? Could this be the issue?
Don’t worry about that, it’s just a way of resetting the device.
You can try reflash the cerbo if it persists.
You’re not using the wifi for anything?
Thats correct. I am only using LAN connections for my energy system.
If i need to reflash the device, i just need to press this button or can/should i do a backup before?
No, you need to follow the reset to default process in the manual - requires a SD/USB drive and the relevant firmware download.
