New device on Cerbo
I currently have my solarsmart mppt for my PV showing on my VRM portal and on the Local tab on my bluetooth no problems. I have just installed an additional solarsmart mppt for my hydro. It shows on the Local tab on my bluetooth on my phone but doesn’t appear in the Devices list on the VRM portal. I’ve restarted everything and rebooted the Cerbo to no avail.
I assume that you have connected the new MPPT by VE Direct cable to the Cerbo. The VE Direct cable would be the thing to check. DIY cables if used are notorious for poor connections.
Hi there. Thanks for your reply. Yes I have and it’s the VE cable supplied by Victron with the mppt. I tried it on the existing solar mppt and it worked fine. I also tried a different port on the Cerbo and it’s not the port.
