No ve.direct communication with MPPT 150/45 and Cerbo GX
My SmartSolar MPPT 150/45 won’t communicate with my Cerbo GX.
In addition I have two MPPT 250/85. The two 250/85 and the 150/45 are connected via a isolated vedirect<->usb converter and work fine except the 150/45. If I connect the 150/45 directly via ve.direct to the Cerbo its still not showing up. I tried different cables. Even with an original cable from Victron the 150/45 is not showing up in the device list.
One of the three ve.direct ports is used by a SmartShunt which works fine.
If I connect one of the 250/85 directly to the Cerbo it show up in the list.
Is there a way to troubleshoot this problem via ssh on the cerbo?
The MPPT is running firmware 1.64 the Cerbo 3.60~78 (with factory firmware and updated stable firmware I had no luck, so I tried the latest and still no luck - everything else works fine).
Thank you in advance for any help.
(short info about my setup: 2x 15kwh lifepo4, 2x MP2 5000 in parralel mode, 2x 250/85 and 1x 150/45 charge controller, “offgrid” with no ac in connection, load and some micro inverters on ac out)
Whilst maybe not a total solution to the debugging problem, if you connect to the cerbo via ssh, you can run a program called 'dbusspy’which will let you know if the ve-direct interface is receiving data.
An alternative - if you have a ve-direct >> USB cable is to plug that into a laptop, and see what is coming in in a terminal window. this should show the text broadcast from the MPPT.
serial format is baudrate=19200,parity=serial.PARITY_NONE,stopbits=serial.STOPBITS_ONE, bytesize=serial.EIGHTBITS
After a long time I had time to deal with the problem again. With dbusspy on the cerbo I can not see the MPPT. Everything else is listed. I now bought a ve.direct to USB cable and used this one to connect the 150/45 to the cerbo and it appeared directly in the list … Does anyone have any idea why ve.direct works via USB but not when connected directly? The MPPT (smartsolar 150/45 rev3) is now running firmware 1.68, the cerbo is on the latest.
faulty VE direct cable possibly…
Use a magnifying glass to check whether any pins in the plug at the mppt are bent.
I’ve had that happen before.
