Multiplus update ess problem
Hello
after i did a multiplus update from 556 to 558 my ess not working proper . Normaly i can change my grid feed in tot the right power . Now it just start to draw power even if battery are half full . Only way to stop that power is in vrm in the menu right on top and set amp to lowest as possible . Solar power is working perfect . Allready did a ess assistant again in ve configure
Grtz
After a FW update all settings are reset to default.
There is a warning about that.
You need to reconfigure the MultiPlus.
Hi Matthias
did the ve configure also . Delete the assistant and add again . Even when input current is at 1amp and battery half full is start to use grid power over battery . If then i disconnect main switch from grid it start to use full battery power .
Grtz
It works , assistant was only applied on phase 1 inverter had to do it on all 3 . Stupid error from me :skull:
