I have two lithium batteries connected to a Lynx Bms connected to a Cerbo GX via CAN bus.
the CerboGX is configured as a VDCC and connected to a Multiplus 12/3000/120-50 230V via VE.bus.
Finally, there’s a 3600W isolation transformer between the multiplus and shore power.
I configured the AC Input Current Limit in the multiplus at 15A (3600W/230V=15.65A), which should give about 246Amps at 14V when charging the lithium bank
the totat current during the bulk phase is always 120Amps regardless of whether there’s one or two batteries connected to the system, so I assume the batteries are not the limiting factor here.
Is there another setting somewhere else I could set?
Thank you !
