Multiplus-II Charging Battery Issue
Hello everyone,
I’m facing the following issue:
My inverter is only charging the batteries from shore power at 150W. I have correctly configured the Multiplus for the right battery type, but strangely it doesn’t charge with full power. Currently, the batteries are at 31.3% state of charge. (Previously, they were unfortunately over-discharged, reaching a cell voltage of 2.74V, which triggered the battery pre-alarm.)
Now I don’t understand why the Multiplus isn’t charging the batteries at its full capacity of 120A.
Unfortunately, I can’t find a comprehensive guide for setting up the entire system (I have already attended a Victron training, but it barely covered the software configuration).
I would really appreciate any help or tips you can offer!
System setup (installed in an RV):
  • Multiplus II 12/3000 (wired with 2x 50mm² cables)
  • Lynx Distributor
  • Lynx Smart BMS
  • 2x 200Ah LiFePO₄ Smart Batteries
  • Cerbo GX
  • Orion XS
Thanks and best regards,
Sven
  • Firmware v556 for Cerbo GX or Multiplus II?
  • Where can I deselect this? In Venus OS on the Cerbo or in Victron Connect?
  • MP is managed by lynx BMS
In the settings of the MultiPlus via VE.config but “weak AC input” is disabled by default.
Add some screenshots from your settings.
