Don’t know where to find the default PIN or PUK. Access via VRM possible. How to reset the PIN?
Hi Andreasdaab,
Welcom to the forum.
The Bluetooth PUK code should be on the product sticker of the Multiplus.
- Connect to the device: Ensure your MultiPlus is powered on and within Bluetooth range.
- Open the app: Launch the VictronConnect app on your smartphone or tablet.
- Locate the device: Select your MultiPlus from the device list.
- Reset PIN: Tap the three-dot menu (or similar) next to the device and choose “Reset PIN code”.
- Enter PUK: You will need the PUK code (Product Unique Key) found on the product label to reset the PIN.
- Confirm: Follow the on-screen prompts to confirm the reset.
Where is the PUK located? Read something about the backside, which would bei a problem since it is wall mounted.
For clarity, are you referring to a Multiplus 2 GX? As a standard Multi does not have bluetooth.
Yes, sorry it is the 48/3000/35 GX version.
That answer looks AI generated.
Human only
Please don’t post answers generated by AI models (such as chatGPT) - it is pretty obvious to the trained eye, the advice they give isn’t always wrong, but it’s never quite right. We’ll delete it and suspend, as it’s used by spam accounts.
