Please could you advice how to connect third MPPT to MultiPlus-II 48 | 3000 | 35-32 GX? My idea is to use USB hub and second VE.Direct to USB cable victron. Is it correct? thank you
Yes! But use a good quality powered usb hub
Thank you for confirmation…any different idea how to connect third MPPT?
What do you mean?
connect third MPPT via bluetooth …if it is possible to combine connection (2 MPPT by wire and thrird MPPT via bluetooth)
I’m using cheap ebay 3 way usb hub, not powered.
This is connected to usb socket on mp2gx with 1no. Usb to rs485( jkbms) + 1no. Usb to ve direct ( mppt 150/45)+ 1no. Usb to usb ( arduino nano -powered from the usb this is controlling a 8 way relay board - powered separately).
Also connected to mp2gx via ve direct are 2no. Mppt’s.
All working ok so far.
For the sake of a £3 ebay hub, give it a go, whats to loose?
No not possible
@1234enough My answer was not directed to you
it was for @radek
