Connection two MPPT Bluesolar 150/70 TR
I have a system with a MPPT Bluesolar 150/70 TR which is connected to a Color Control GX.
Now I want to expand my solar panels and want to add another MPPT. But the MPPT only has one VE-can connection, so I can not link them and add them to the CCGX.
I read there is a solution by doing this via an active USB-hub, will the MPPT’s be synchronized in that way? The two MPPT will be bother deliver the electricity to the same busbars which goes to the batteries.
Your post is confusing. Do you have the VE CAN version, which has 2 VECAN ports and the mppts are daisy chained. If you have this type then look closer.
Or do you have the VE Direct version which only has one VE direct connection. If you have this type then each MPPT has its own connection back to the GX and if you have run out of VE Direct ports on the GX device then buy a VE Direct to USB cable and use that. If you have run out of USB ports then use a quality USB hub.
The VE-direct, only one port.
I still have space on the GX, I checked that. So just connect both to the GX will do the job, that would be great.
Yep, both back to the GX and you will be good.
Ok, thanks.
