How do you access EVCS schedules from VRM
I want to be able to view and change my EV charging schedules via VRM but this function is not available on my system. I have to physically stand next to the EVCS and connect as a local connection. Is this something that could be added?
In my VRM in the menu there is a “Device List” and the EVCS is in that list.
When clicked/tapped I can log in to the EVCS and see all its interface.
Hi David, Thanks for the info. I actually don’t have the EVCS displayed on the device list screen.
It’s only when I go onto the Remote Control menu does it appear and then I can’t access the schedules part of the system so can’t set new schedules.
Those screenshots look like the Victron Connect app.
Do you have the Victron VRM app also? It’s the VRM app I was referring to.
Hi David,
I’ve logged into the VRM app which I already had on my phone. I’m now facing a login screen for the EV device for which there doesn’t seem be a password reset option.
I’ve had a look around at the
settings but can’t see a security area where I can reset the password for this device. Any thoughts?
If you Bluetooth in to the EVCS using the Victron Connect app you can go to
Settings>Access and reset the password there
Got it :+1:
Thanks for your help.
