Hi I’m still new to victron, I have a victron EV charger installed last year due to part of our planning to build our house. We have only just got an EV car. I can charge the car manually but it’s not showing on my app
I have pressed the touch screen a few times on the ev charger and I can see it’s connected to my WiFi.
Sorry, I should have asked - do you only have the Victron EVCS EV charger, is it a stand alone device or is it part of a larger Victron solar and battery system?
I was presuming from my original reply that you have other Victron solar products such as Quattro or Multiplus and centrally controlled by a Cerbo GX or other GX derivative.
My response was presuming you were trying to integrate into a larger system.
I believe if you are using the EVCS as a stand alone charger, you need to use the Victron Connect app which connects via Bluetooth.
