Setup:
Multiplus 2GX with Dyness G2 battery. Grid and PV meters (Iammeter) connected through Modbus TCP. PV installation AC coupled on AC IN with the GRID.
I seem to get all interconnected (battery via VE.CAN).
On the dashboard Grid value is refecting my Grid meter (can somebody confirm when I feed into the net the value should be negative), my PV value correctly refects the output of my Solar inverter and the Battery value correctly reflects the charging-load of the battery.
Whats does not make sense is the AC loads who seem to be +_ indentical to PV output instead of showing me the delta from PV output - GRID so in the picture it should be 2222W - 255W = 1967W.
Any suggestions what I am missing?
