I bought the MK3 with my Multiplus and wanted to use it to update the configuration settings. I disconnected the VE.Bus (ethernet) cable from the back of my Ekrano GX and used that to connect to the MK3. I also disconnected the SeeLevel from the and VE.Can (ethernet to Garnet 4 pin) and the Can terminator. I connected the Multiplus to my laptop and was able to use the VE Config and Victron Connect apps to update the Multiplus. When I reconnected the VE.Bus and VE.Can connections on Ekrano lost my SeeLevel sensors. Is there a way to reset the VE.Can? I only have one device in the Can 1 bus and have a terminator in the empty port on Can 1.
Related topics
| Topic | Replies | Views | Activity | |
| Ekrano loses contact with Multiplus after using the MK3 to update the Multiplus configurations | 3 | 75 | 25 April 2025 | |
| 3.50 / 3.51 : VE.CAN losing connectivity to VM-3P75CT (Grid & AC Loads Enphase) | 11 | 680 | 11 January 2025 | |
| Multiplus II GX missing ve.can ports? | 8 | 183 | 24 June 2025 | |
| Warning: 67 BMS connection lost | 28 | 382 | 6 September 2025 | |
| Cerbo GX MK2 keine VE.can Verbindung zu 150/100 TR VE.can | 5 | 62 | 27 July 2025 |
