@Lpopescu, can you assist me here ? I talked to Matthijs on Friday ( on the Cerbo MK2 issue ) and he mentioned you are the one to get this either solved or explained.
I have the feeling that there are a few topics opened on the upgrade issues to FW.2.0 and some people are in a different stage/phase of the upgrade encountering problems
Example : Cannot access EV charging station Control Panel after firmware 2.0 update
I passed that stage already and now have a bricked EVCS after doing the DEF procedure.
My problem phases were :
- upgrade from 1.27 to 2.00 resulted in a working and accessible EVCS but display issue ( so firmware of the display not loaded correctly )
- trying to correct the display issue by consecutively trying to upgrade manually as per your advice.
- No luck in getting the display to work but now the EVCS is not accessible by browser only by victron connect. The device is pingable ( but very poorly ). Looks like a bad network connection low latency but its clear the software at fault here not responding fast enough.
- However as it seems to be network I tried to reset the WIFI settings which resulted in a double presentation of the WIFI profile. So WIFI SSID is shown twice !!
- As it now seems that the EVCS has configuration issues I tried to use the DEF procedure after which the default WIFI AP and or BT should be used to “reconfigure” the EVCS.
Sadly enough … no BT and no default WIFI AP to connect to …
The screen still shows " loading with the dots stil animating"
Need to know if to send in for RMA or if we you have a solution.
But I dare not to upgrade and help my clients to V.2.00 as this is getting so time-consuming.
