i made update from 2.0 to 2.02.
After Update the cable needed a calibration but the button was gray.
So i made restart nothing changed.
I tried with reset.
After reset the EVCS shows error w-101 N-301 N-303
Bluetooth isnt working
Wifi is possible to connect but no access to page 192.168.0.1
Hello @tbader
Check if you are using HTTP instead of HTTPS. The correct address to open the EVCS web interface should be http://192.168.0.1
Some browsers may add https automatically.
N-303 - Appears when the ‘Start’ button is pressed but the car is not connected to EVCS.
Are you sure the cable is well connected to EVCS and EV?
Which EV status did you see in the VRM, web interface, or VC(Disconnected, Connected, waiting for start, etc…)
N-301 - Appears when attempting to set Auto mode but GX communication is disabled.
My car is also not detected (N-303) on both units, yes I have two EVCS, both with screen.
I had to calibrate CP line manually in the past for each Tesla. Can I revert the firmware?
I got the major problem the display of my EVCS is staying in “Loading..”. Version 2.0.1 and 2.0.2 have the same issue. I’ve up/downgraded between them, did multiple installs.. only way to control my EVCS is via webinterface.. not compatible with my wife tho
Fuse blew for the EV charger overnight, unit still alive but doesn’t want to charge anymore. Updated firmware from 2.02 to 2.03 but no luck. The lcd still flickers and I am getting all the errors related to the screen firmware being updated and not being able to start a charge while updating etc .
Any ideas how to resolve the ‘non charging’ issue and the screen flicker? @Nicolas
Incase anyone comes across this. I just installed a unit in July 26. Version V2.5. Was coming up Error N-303 - car not connected. I downgraded the firmware to V2.1 thorough the IP address. I was then able to calibrate and all worked correctly. Things to note that I had issues with the firmware downgrade and calibration. I Was able to use the webpage (ip address) to downgrade firmware but the calibration was throwing an error. To calibrate I went through the app and connected via Bluetooth.
