EV Charger not able to charge. Displays charged
I’ve installed an EV charger and it connected to the GX device but I face 2 issues
1- not showing up on VRM. Although the EV portal on the IP address sees the install and shows all info about MPTT, batteries … VRM doen’t reflect the newly installed EV Charger !
2- I cannot charge my electric vehicule as it goes from “starting” to “charged”. I read about calibration but it seems to have evolved along the versions and be automatic but not sure how long it takes and what I can do today…
Same whether it’s manual or auto. Latest Firmware.
I have exactly the same issue.
Since firmware v2.07 the EVCS will go into “charged” state after a few minutes of charging.
My car (Mercedes EQS) will display a charging error when this happens.
I reverted back to v2.05 and all keeps working.
My 2nd EV car (Jeep Avenger) doesn’t show this error (same charger). So it looks to me the combination with the specific car is what triggers it.
@dfaber im not fully sure you are involved with EVCS, if you do:
In the changelog of v2.07 I read: “Fixed an issue with CP auto-calibration that could prevent connected EVs from being detected on some charging stations”. I have a feeling that made it broken for us.
Im able to help / test, VPN connection directly to EVCS available. Location: Culemborg, NL - SiteID: 464460.
Version 2.08 came out June 10. The change log is a bit vague: "Updated to the latest BLE SDK with stability and performance improvements ".
Have you tried enabling the manual CP Calibration per section 6.1? https://www.victronenergy.com/media/pg/EV_Charging_Station/en/troubleshooting.html#UUID-08f76853-124a-0e78-fd7b-0ae95bb0933d
Yes, I’ve had manual cp calibration enabled at some point on v2.08. But this also didn’t help and eventually I went back to v2.05 and all started working.
*** after the downgrade I’ve enabled auto calibration again, as it worked flawless on previous firmwares and since i have multiple cars I benefit from the auto cp calibration.
If there are stil issues, please tag me, I’m not always seeing all the posts EVCS related.
After a good charging session on the old firmware, I now got the error back again so I start to think its not EVCS firmware related but rather car firmware related. Too bad we dont get downgrade options and/or changelogs for those >_>
Hi Lucian,
Sorry for delay as I’m back from hols
yes the issue is still not resolved
Ok, I will ask in a private message for some details to connet to your system and check it togheter
Bonjour,
Je viens d’installer la borne et j’ai le même problème.
Je n’arrive pas à acceder au calibrage CP (aucune option)
EVCS v2.08
Merci
in addition I realise that the EV charger
does not appear in VRM
does not appear in device list
appears in the firmware update (device list)
does not appear in VictronConnect when connected to easy solar
Why is this inconsistency and how to remove it?
