Connect 2 victron MPPT to Ccgx
Greetings from Denmark
My system is Multiplus 3000 and CCGX plus 712 and control panel.
I need to connect 2 victron mppt but there is only one ve direct port available (the other being used by 712/control panel)
Is it possible to connect one mppt using a ve direct cable in the free ve direct port on the CCGX and the other using a ve direct to usb to connect to a USB port on the CCGX.
The CCGX are around 1.5 meters from the two MPPT
Or is there other solutions?
THANKS and regards
Lasse
You are correct, when all VE Direct ports are full you use a VE Direct to USB cable. Buy a proper Victron cable, DIY cables can cause problems.
