Hi everyone,
I’m having an issue with a new Victron installation. For some reason, the Nucleo GX can’t detect the ESS Assistant installed on the MultiPlus units. The units go into passthrough and stop charging the battery.
Here’s the setup.
3 × MultiPlus-II 48/5000/50-70
1 × Nucleo GX
1 × EM540 as the grid meter
1 × ET340 as the PV meter
2 × Hoymiles MIT-5000-8T inverters connected on the AC-in side
I first updated all three MultiPlus units to firmware v568, which was the latest version available to me. I then configured them as a three-phase system using VE.Bus Quick Configure. I also checked the setup in VE.Bus System Configurator and didn’t see any significant differences.
Once the three-phase setup was complete, the units started up. When I applied AC input, they synced with the grid and started charging the battery bank. The batteries are configured for voltage-based charging, with no remote battery management.
Next, as I usually do on this type of installation, I right-clicked each MultiPlus in turn to open its settings. I selected the grid code, set the charging voltages and current, and added the ESS Assistant. I repeated this for all three units.
Once I’d finished configuring them, I plugged the MK3-USB interface into a spare USB port on the Nucleo GX. The MultiPlus units show up in the Venus OS device list, and I can see their live readings. But when I try to configure ESS, Venus OS reports that no ESS Assistant was found.
Has anyone run into this before? What should I check next?
I also spoke to my equipment supplier. Their technician suggested there might be an issue with how I’d uploaded the ESS Assistant and recommended trying Remote VEConfigure. That didn’t solve it either. The settings did go through. I changed the AC input current limit to verify that the new configuration had been applied, and the new limit showed up. Venus OS still couldn’t see the ESS Assistant.
Has anyone run into this before? Could it be related to the new Nucleo GX or to my older MK3-USB interface? Mine is the version with a detachable USB cable. What would you check next?
