Noob with MP2GX that won't turn on the inverter
Brand new system with an MP2GX v3.79 firmware and a Pytes V16 battery, turned on for the first time today. Created an account on VRM and sort of got it showing as an installation, but the device list also showed a PV Inverter from 22 days ago, so to be safe, I deleted the install and did a factory reset. Now it just shows a single device marked as Gateway., VRM dashboard is blank and the control panel on the MP2GX just says Status OFF. No sign of a battery. Where do I go from here?
Have you configured the inverter and GX?
I don’t seem to have any ability to do anything. The inverter doesn’t even show as a device, and there are no options to do anything with the GX in VictronConnect or VRM. Do I need to get special cable?
Yes, you need to configure both devices. These are not consumer products, you either need to research and skill up with all the available (and free) docs/video training, or get a professional to help you.
Thanks, but how do I configure them if I can’t connect to them? I have VEConfig and I understand I need to up/down load the config files, but I can’t connect to the devices. I have a degree in electronics, FFS, and work in IT…
The process is quite well documented, you can use the internal AP/ blueteeth to get the GX online or configured. You need a mk3 usb adapter to configure the inverter.
Follow the basic video training on the professional site, all will become clear. IT experience won’t help here beyond getting networking working.
Thank you. Nowhere had I seen anything to suggest I needed an MK3 cable. Who on earth designed a single unit that needs two different connections to configure???
If you can’t get it online your only means of configuration is the adapter. If the proverbial hits the fan, you need the adapter.
This is not new in any form. Anyone aspiring to commit to a diy project needs to do the training and research to be prepared. If that is done, this will not be news.
As the saying goes, fail to plan, plan to fail. There is an extraordinary record of information on this forum alone.
Well, I bought a Mk3 to USB cable. VE Configure couldn’t detect anything (how old is that app, btw? It looks like it was written for WinXP). VictronConnect managed a little better: it was able to detect a VE.bus device but couldn’t connect to it. So I’ve raised a ticket with the supplier and we’ll see what next week brings. The random config changes and the fact it thought it had a PV inverter three weeks ago makes me think someone shipped me a dead RMA’d unit, but who knows?
Ah yes, welcome to the veconfigure debate :wink:
I would suggest you try download veflash and see if that helps to reflash the unit.
Usually you disconnect the gx as the mk3 and gx can conflict, this is more challenging with an internal gx.
Maybe you have been unlucky with a duff unit, it shouldn’t be this complicated to get the GX configured.
Maybe pop the cover, please be careful, and check nothing came loose in transit. Wouldn’t be the first time.
The cover was already off as it was bolted to the internal backplate in an IP66 steel cabinet before we installed it, so my son (a fully qualified sparkie, btw) gave everything the once over. I take it that the USB stick factory reset is resetting the GX only, or is it doing the inverter as well? Remote console is fine, VRM has decided it does have internet access after all and it updated successfully to 3.81, but I think that is just the GX, right? And that internal GX board appears to be a RasPi device, is that correct? I can’t remember where we saw that, but something came up as a RasPi…
Its not a Pi. The GX and inverter are different devices, the gx code is currently 3.81, the inverter is 5.68. An inverter update scrubs its settings, but it must be reachable.
Make sure the internal gx to inverter connection cable is connected.
Well, it was at one point, then it wasn’t, was again and now it’s not, so make of that what you will. I will check with the lad, but something came up as a RasPi…
I don’t use the GX variants for various reasons, the range details are available here:
You shouldn’t be struggling like this, so something is off.
Hope you come right.
The lad just reminded me, the RasPi thing showed up in the Netgear router list of connected devices, once this poor ignorant IT gnome re-established the network connection to the GX. Victron may deny it, but this is how Netgear reports it…
Indeed but nanopi and raspberry are not the same things.
The gx’s are all based on existing iot architectures, beaglebone etc.
Ultimately they all share common silicon packaging.
Ah, ok, seems to be a bare bones version of a Raspberry Pi running a custom Linux distro. Haven’t played with these in a good few years, but I think have a few Arduino boards in a box in the loft…
The internal gx has good processor power, just short on memory and external connections. Not that any of that affects your current challenges.
I cut my teeth hand assembling machine code to hex on an EPROM burner for 8080’s, so anything capable of running Linux is a supercomputer
I started banging out assembler gaming code on a zx81, spectrum and c64 to have the most awful text based entertainment. Fairly sure I invented carpal tunnel :grimacing:
NASA had less horsepower to send people to the moon.
