Dear community,
At the risk of getting told off for not introducing myself and possibly not having searched thoroughly enough.
But things are rather desperate at the moment, as we’ve been without power for hours.
I have 3 MultiPlus II 48/3000/53-32 units, one of which is a GX, together with a Pytes E-Box 48100R battery via Smart.Solar MPPT 250/70.
That’s the extent of my technical knowledge. The system is installed as a backup-power setup across all three phases. This means that mains power also runs through the inverters.
I’ve been having blackouts since Wednesday. Initially, the system recovers after 5–10 seconds. Then, after about 30 minutes, it starts switching off and on every 10 seconds, until it eventually shuts down completely.
Swapping the communication cables beneath the inverters on Wednesday gave me hope that the problem was solved. Far from it—last night, the same thing happened again. Since then, there’s been no power in the house.
Error messages:
#1 Device switched off
#14 Device communication error
#3 Error with expected devices
Yesterday, the app also showed a red bar reading: VE.Bus System [275], VE.Bus Error 3
I’ve contacted my electrician for today so that he can bypass the system and at least restore mains power for me.
Has anyone encountered this problem before and know whether it’s likely to be software- or hardware-related? English and technical jargon aren’t my strengths. My mate installed everything for me, but he has now reached the limits of his experience as well.
I’ve just restarted everything—that is, switched all the inverters off, waited 10 minutes, and switched them back on. It’s running. But of course I’m not counting my chickens just yet. I’ve already had this happen a few times.
Thanks, Daniel from Dollbergen near Hanover—or Peine
