leigh avatar image
leigh asked
Which Controller?? Help please:-)
Hi all
I have a 12v system they are 2 x 12v @ 220ah so total of 440 ah on my boat.
I have been looking at the following panels and would like to install 2 or 3
- https://klimaenergi.dk/wp-content/uploads/2018/08/Vikram-SOMERA-Ultima-60-CELLS-1500v-Full-Black.pdf
Even after quite a bit of research and attempting to understand how to calculate it. I always end up with an extra unsure thought..
I have come to the conclusion that a reputable MPPT controller is key there for I decided on victron
So which MPPT controller would I need for 2 x these panels
And which if I get 3 of the above panels
Or is there a better scenario you could recommend.
Your help is greatly appreciated
mppt charging
JohnC avatar image
JohnC answered ·
Hi @Leigh
Try this calculator.. https://mppt.victronenergy.com/#
Those panels would work ok in Parallel into 12V batts. Or you could even do one (smaller) mppt for each panel if you had selective shading.
But have a play. Come back as you need.
4 comments
leigh avatar image leigh commented ·
Thanks, I entered the info into it before posting this but It would not let me add a battery float of 13,4v ..
Both panels are on the highest point of the boat and should have not shade.
JohnC avatar image JohnC ♦ leigh commented ·
@Leigh
Don't worry about the float V, it will compensate for that itself.
My guess is that it will calculate ~/20 capacity for each panel, but the range doesn't fit exactly, so probably 100/20, 100/50, and 150/60 for 1,2,3 panels. The 150/ is likely a steeper price stepup but you could possibly run 3x in a series string.
The 100/50 would rarely limit you into 440Ah of batt, even with 3x panels, and would probably be a good choice for either 2 or 3 panels.
leigh avatar image leigh JohnC ♦ commented ·
Thank you John
Is there a big advantage by running 3 x in a series.
If I read correctly on an average day 3 of the panels will run fine through the 100/50 given my bank size? Perhaps my calculations are wrong but 3 should refresh the batteries every 24 hours + -
I am not a huge power consumer on anchor. But the batteries get close to a critical level after 1.5 days. So i am trying to extend that rather than install a generator or run my engines;-)
