en-b avatar image
en-b asked
GlobalLink 520 Digital Inputs
I have 3 GlobalLink 520s and I'm trying to use the digital inputs to monitor the state of a relay. On 1 unit, both digital inputs are normally high and I'm able to use a relay to pull them low by attaching them to ground. On the other 2 units, digital input 1 is normally low and digital input 2 is normally high. According to the manual, both digital inputs should be normally high. What would be causing the digital input to be normally low on those 2 units? There is nothing connected to the digital input that is normally low.
globallink
Hi @EN-B , sorry for the long delay; I was alerted to this. Has this been solved meanwhile?
There are only two reasons I can think of: error in your wiring or damaged GlobalLink(s).
