zameer-andani avatar image
Can I stack multiple loads on an ouput within a lynx distributor?
I'm trying to layout the electric in my camper van and am thinking of having 2 DC fuse blocks (passenger's side, driver's side).
I have 5 loads in total (1 inverter, 1 dc-to-dc charger, 1 solar, 2 dc fuse blocks).
Rather than buying 2 lynx distributors, I'm wondering if I could just stack the +ve and -ve of both my fuse blocks onto a single load output in the lynx distributor (of course adjusting gauge and fuse).
Is this recommended, or not - can anyone highlight issues in doing this?
ESScampervan
jerothle avatar image
jerothle answered ·
Hi Zameer, I did as you describe. 4/0 welding cable for inverter (with mega fuse) on one set of the buss bar bolts, and on the other bolts with fuses; 2 gauge, 4 gauge, up to 6 gauge for remote fuse blocks. The Panduit lugs I used don't stack well together on one bolt when using fuses across the buss bar bolts.
seb71 avatar image
seb71 answered ·
Always avoid puting more than one wire lug on a bolt (especially for high current/Amps).
You can use the other end of the busbar for the 5th wire.
