Cable lengths
Cable lengths
I would put the shorter cables between the charger and the battery since it allows the charger to more accurately measure the battery voltage.
Thicker cables on the input is best especially if you have a long run, say from the alternator to the the back of the RV or van as thiner cables although may carry the current may cause a voltage drop to the Orion inputs to cause the unit not to sense if you are using auto detect. But that is a balancing act cost, Orion has a 16mm2 terminal long run of 16mm2 could be expensive and difficult to run. Used compromise 10mm2 x 3m works well
Orion-Tr Smart Dc to DC Charger, Alternator Victron Energy
__________
Orion-Tr Smart DC-DC Charger Isolated 12 / 24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Datasheet
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Online Manual
__________
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Datasheet
__________
32 People are following this question.
