larryg avatar image
larryg asked
SmartShunt Tail Current Calculation?
From SmartShunt Manual, Section 7.1.4:
The “Tail current” parameter is expressed as a percentage of the battery capacity.
As I understand it, the unit of "tail current" is Amps; the unit of battery capacity is Amp-Hours. A percentage of Amp-Hours is still Amp-Hours.
How does the SmartShunt calculate an amperage from a percent of battery capacity?
BMV Battery Monitor
pwfarnell avatar image
pwfarnell answered ·
Theoretically, the tail current the the percentage of the 1C charge rate of the battery (the current flow required to charge the battery in 1 hour), so if you have 400 Amp-hour of batteries, the 1C charge rate is 400 Amps and if your tail current is 1% then it is 4 Amps. This makes the units correct, but simply it is the percentage of the numerical value of the battery capacity.
justinb avatar image
justinb answered ·
What would you set tail current to on 12v. 460ah? Is there some sort of equation for this?
@Justinb
It depends on battery chemistry as well. But the 4% default is a good place to start.
More on Tail current here.
Tail current is 460*4/100=17.6A.
To elaborate on @pwfarnell answer, Amp is actually a rate defined as 1Joule per second at 1 Volt. So the short cut of % of capacity in Ah is logical and consistent and eliminates more complex calculations.
