mac avatar image
mac asked
2 Pylontech US2000C charges only with ~ 12,5 A
Good morning,
my two Pylontech US2000C do only charge and discharge with 12,5 A. Also both batteries show CCL and DCL 25.0A. What goes wrong and how can I fix this. The cabeling is OK and checked.
The other eqiupment:
MultiPlus-II 48/3000/35-32 (V 481) , Cerbo GX (V 2.66), EM24
Pylontech
Alexandra avatar image
Alexandra answered ·
Has the system been set up according to this page https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom#gx_device_settings
On the cerbo under battery and parameters what does it say there?With 2 you should have at least 50A
If weak ac is checked on the inverter programming, this can also happen since you havent mentioned solar i assume you are grid charging.
mac avatar image
mac answered ·
thank you for answering.
In the meantime I've installed a third Pylontech US2000C.
But I see under Parameter only 25A, for my understanding this should be now 75 A.
Now to you questions:
Yes, the system is configured exactly to your offered page.
The weak AC is not checked.
Any ideas ?
MultiPlus-II 48/3000/35-32 (V 482) , Cerbo GX (V 2.66), EM24
Rob Fijn avatar image
Rob Fijn answered ·
Hello Mac, Maybe you can try to change other battery as the master.. See what happens then.
regards, Rob
