bslbatt-battery avatar image
bslbatt-battery asked
BSLBATT Energy Storage Battery and Victron Connection Problem
In early 2021, we have been officially added to the system by Victron.
https://www.victronenergy.com/live/battery_compatibility:bsl
We are very happy! But some users did not find our management system when they used our energy storage system to connect to Victron.维克多.jpg
Because we have just joined Victron inverters, if you are still using the inverter system for a long time, then our brand will not be displayed.
It's important to update all software and firmware to the latest version to see our brand.
bslbatt
mouanda avatar image
mouanda answered ·
We have connected the Quottro/BSL system according to the Diagram provided.
But, we encountered a problem, as soon as we connect the DC power part (- and +) and Durring commissioning, as soon as we switch on the disconnector/circuit breaker Be tween the batteries and the inverter, the two batteries are tripped , knowing that the inverter is in the off position.
So we want to know how to solve this problem.
And why? what is the cause?
Cordially
Probably the large caps charging in the inverter causing them to trip. Following the precharge procedure should help.
mouanda avatar image mouanda nickdb ♦♦ commented ·
Ok, je vais essayé le test, merci.
lucca371 avatar image
lucca371 answered ·
How works the precharge procedure? I found nothing about it.
Victron & BSLBATT Lithium batteries
