André Jerleke avatar image
André Jerleke asked
ESS faulty setting? load not taken from battery at all
Hardware details:
  • 3 x MultiPlus-II 48/3000/35-32 230V (3phase-mode) (one of them is a GX model)
    • Firmware: v502
    • GX Firmware: v.300~36
  • 3 x BSL Battery LiFePO48 Battery 10.2kWh (600Ah in total)
  • 1 x Fronius Symo 10.0-3-M
    • 19 x LONGi 445W mono panels (LR4-72HPH-445M)
  • 1 x SmartSolar charge controller MPPT 100/20 with below panel as backup
    • 1 x Trinasolar TSM-335 335W (as backup feed)
Setup details:
  • Grid connected to AC-IN
    • Grid feed-in: AC-coupled PC - feed in excess
  • AC-OUT-1 is feeding essential loads
    • AC-OUT-2 is not in use
  • ESS mode: Optimised (with BatteryLife)
  • Peak shaving: Always
Issue description:
Hi!
Maybe im just thinking this wrong but im not able to get house to use loads from battery, it´s always using grid, i forced it to take from battery by cutting the mains to the house and forcing offgrid mode that way, then the battery started to feed the house (1.9kWh in picture) otherwise never. Peakshaving aint seeming to work and night time (after 19:00 until 07:00 in morning) i would like it to use battery instead but no luck.
Maybe im ust thinking wrong or missing something in the setup?
ESSbslbatt
Paul B avatar image
Paul B answered ·
I use without battery life, but you need to look at the settings in your ess control especially the max soc and your grid set point
https://www.victronenergy.com/live/ess:quick-installation-guide
