bertie-bezuidenhout avatar image
bertie-bezuidenhout asked
Venus Docker Grafana 64-bit Images
Good day
I have a 64-bit Raspberry Pi 4 with an Ubuntu operating system on which I have installed a 64-bit Docker system.
Now I am wondering if anyone can help me to find the venus-docker-server, venus-docker-grafana and venus-docker-upnp images that I can use, if such images are available.
Regards
grafana
Moved to "Modifications" Space for non-Victron-supported systems and interfaces.
kenthusvik avatar image
kenthusvik answered ·
Having the same issue.
Pulling server (victronenergy/venus-docker-server:latest)...
latest: Pulling from victronenergy/venus-docker-server
ERROR: no matching manifest for linux/arm64/v8 in the manifest list entries
use with "sudo" command
Marcel avatar image
Marcel answered ·
I recently installed this on an OrangePi running on Armbian.
With some trial and error I now got it working.
The steps i followed:
1. install docker for linux as described on the docker site. https://docs.docker.com/engine/install/ubuntu/
and test it with hello-world
2. Install the docker compose command. (this was missing
sudo apt install docker-compose
3. add user pi to the system
useradd pi
4. give it a password
sudo passwd pi
5. add pi to docker
sudo usermod -aG docker pi
6. create directory victron in systemroot
mkdir victron
7. download the docker-compose.yaml from https://raw.githubusercontent.com/victronenergy/venus-docker-grafana/master/docker-compose.yaml
8. Edit the Yaml file (and this makes it working)
change all the image instances from: "victronenergy/venus-docker-server:latest" to "victronenergy/venus-docker-server:armhf-latest"
mine now looks like this:
version: '3.4'
services:
  server:
    image: "victronenergy/venus-docker-server:armhf-latest"
    ports:
     - "8088:8088"
    volumes:
     - "config-storage:/config"
  upnp:
    image: "victronenergy/venus-docker-upnp:armhf-latest"
    network_mode: host
  influxdb:
    image: "influxdb:1.7"
    ports:
     - "8086:8086"
    volumes:
     - "influxdb-storage:/var/lib/influxdb"
    environment:
     - INFLUXDB_HTTP_LOG_ENABLED=false
  graphing:
    image: "victronenergy/venus-docker-grafana:armhf-latest"
    volumes:
     - "grafana-storage:/var/lib/grafana"
    ports:
     - "3000:3000"
volumes:
 influxdb-storage:
 grafana-storage:
 config-storage:
9. execute command docker compose up
docker-compose up -d
10. The command at point 9 showed the same results as Matthijs had in his video. During pulling and building the Victron-Grafana code it looked like this:
11. After the complete messages I browsed to the http://localhost:8088 and got the following dashboard overview:
I then were able to connect my VenusOS raspberryPi and pulling data from it in a grafana dashboard
The only thing I now need to figure out is how to automaticly start the Venus-docker instances after a reboot of the Pi.
I now restarted them by exceuting the command docker-compose up --d But I want them to start again at a reboot.
The reason I edited my docker-compose.yaml file was the following.
I fresly installed docker and confirmed it was running hello-world. The documentation stated it is a standard image.
I then searched the docker site for victronenery and found the following containers on their site:
https://hub.docker.com/search?q=victronenergy&type=image
I then went to https://hub.docker.com/r/victronenergy/venus-docker-grafana/tags
I there found some info on architecture; chose the armhf-2.0.2 as this sounded most logical to me.
Hope this helps someone in the future.
regards,
Marcel
dunnp avatar image
dunnp answered ·
Hi Marcel.
A trick I discovered was to force a restart of the services in the docker-compose.yaml file.
Four places - highlighted in blue below. Just re-run docker-compose up after the change. Worked for me; hope it works for you.
server:
image: "victronenergy/venus-docker-server:latest"
ports:
- "8088:8088"
volumes:
restart: always
upnp:
image: "victronenergy/venus-docker-upnp:latest"
network_mode: host
restart: always
influxdb:
ports:
- "8086:8086"
volumes:
environment:
restart: always
graphing:
image: "victronenergy/venus-docker-grafana:latest"
volumes:
ports:
- "3000:3000"
restart: always
volumes:
influxdb-storage:
grafana-storage:
config-storage:
Marcel avatar image
Marcel answered ·
Hi dunnp,
Thank you for your Help. I indeed found an older post from in which you;'ve mentioned the same. But I got an error message when I've added the restart line.
root@Grafana-host:/victron# docker-compose up --d
ERROR: yaml.parser.ParserError: while parsing a block collection
in "./docker-compose.yaml", line 8, column 6
expected <block end>, but found '?'
in "./docker-compose.yaml", line 9, column 6
I edit it with Notepad ++ insted of the editor in linux
I think I got it. When editing in Notepad++ it autmaticly groups the commands.
I've removed a [ ] space which made it an individual entry.
After that I restarted the command:
Recreating victron_upnp_1 ... done
Recreating victron_influxdb_1 ... done
Recreating victron_server_1 ... done
Recreating victron_graphing_1 ... done
I've rebooted the Pi and indeed now my dashboard is instantly..
Now it's time to start customizing the dashboard.
Thank you for your help.
sureshskr avatar image
sureshskr answered ·
Finally have Grafana running in Rpi 64-bit OS
rob-wilson avatar image
rob-wilson answered ·
Hi, I have just tried getting this to work with the following versions:
Raspberry Pi OS (64-bit)
  • Release date: April 4th 2022
  • System: 64-bit
  • Kernel version: 5.15
  • Debian version: 11 (bullseye)
Along with latest venus-grafana-docker (as of today).
Everything works fine on my m1 macbook, but when adjusting the docker tag for each image to `armhf-latest` to run on the raspberry pi, I get the following error in grafana:
Has anyone else experienced this and have any idea how to fix?
Many thanks!
For anyone else encountering the above issue, I managed to solve it by changing the venus-docker-grafana tag from armhf-latest to armhf-2.0.0 since armhf-latest isn't actually the latest build for the grafana image. The other two image tags remain as armhf-latest.
It also looks like someone else also found another possible solution by building their own image - they talk about it here: https://github.com/victronenergy/venus-docker-grafana-images/issues/12
