So here's my plan:
Is 620W of Solar overkill for this system?
No. Far from it. If you have room to install them, you could get 3 of those 210W panels (or two larger ones).
You could also consider removing the 100W panels and installing 3x210W (with a single charger), if you can fit them. Or two larger panels (~300W each).
The caveat is that factory-installed panels are quite expensive ($400+ a pop), so I'd prefer not to trash them. At least they're lightweight, but to your point, they consume precious roof-top space... But if I can find a buyer for the 100W panels, I may do just as you're suggesting!
Thanks!
That price must include the labor to install them (and a hefty profit). Don't expect to sell them with such price.
The batteries are already wired?
With batteries in parallel, best would be to use a pair of wires for each (with a fuse on each positive wire and with positive wires of equal length and negative wires of equal length).
Or at least connect the negative wire (or the positive wire - whichever is easier) to the other battery. So that the "main" positive and the "main" negative of your battery bank are not on the same battery.
26 People are following this question.
