michelg avatar image
michelg asked
SmartSolar 150-100 / Error 39
Hello everybody,
I just checked physically tonight all my installation, and after switching off the emergency breaker, I got an error 39 ! Currently the Smartsolar detects the correct voltage, but the voltage battery remains blinking "24", and I can change it to 48. BTW, it is currently at night,. so no power coming from the panels.
First time I see the error, and I don't know if it is informationnal, of if for any reason the Smartsolar would have been damaged.
Any comment, information is welcome, thanks, Michel
MPPT SmartSolar
Alexandra avatar image
Alexandra answered ·
@MichelG
You may need to reset it. Then set it up as a stand alone again. Check its function. Then set it up in your system again.
Here's a neat thread for that. You don't need to clear the history. https://community.victronenergy.com/questions/21583/restore-smartsolar-mppt-15070-to-factory-defaults.html
https://www.victronenergy.com/live/mppt-error-codes#err_38_err_39_-_pv_input_shutdown
Is the explanation for why you are seeing the error and recovery options.
michelg avatar image michelg commented ·
Hi Alexandra, many thanks for your help.
Michel.
