nevada avatar image
nevada asked
Inverter RS 48/6000 , programmatically shutting off charger
I have a well with a solar pump. When the sun is out and the float switch is tripped in a tank, a 3kw / 240v dc pump starts using power via a controller.
Most of the time though, like 95% of the time, the 4kw / 240v dc array is being unused.
I'd like to hook an RS 48/6000 up to charge batteries and create 240v ac for a nearby cabin.
So I *think* I'd like someway to tell the victron controller "hey, stop using power when the pump wants it."
Worst case I could do some serious electrical engineering with high capacity relays and arduino but I'm hoping there's a simpler technique via built-in victron functionality.
MPPT SmartSolarinverter rs
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
Inverter RS Product page.
Inverter RS Online Manual.
Inverter RS Datasheet.
