Craig Donnelly avatar image
Craig Donnelly asked
Smart BMS CL12/100 System
Hello, I'm planning to install the Smart BMS CL12/100 to charge 2x 100Ah LiFePo4 House Batteries (with internal BMS), would like to check what else I may need to complete the system.
My Alternator is Balmar 100A with regular internal controller.
I'm planning to charge a 75Ah Lead Acid Wet Starter battery, and 2x 100Ah Lithium House batteries with the BMS CL12/100 unit, I selected the 80A Fuse which I believe will limit the charging current with approx. 70A to the Lithium batteries.
Do I need anything else do I need to complete the system? Other Recommendations?
Balmar has a couple of options for External Charge controllers incl. with Lithium charging programs if required.
Also, my shore power charger is a Victron Blue Smart Charger 12/25 unit already installed.
Anything else needed to use this with the proposed BMS and split battery types?
Suggested wiring would be great if available.
Thanks for help in Advance.
Craig.
BMS
