abeness avatar image
abeness asked
Blue Smart IP67 Charger housing temperature
My Blue Smart IP67 12/25 Charger housing reaches 140 degrees F (as measured with one of those laser temp guns) when charging my 100AH LiFePO4 battery at 25A for an extended period. Pretty much too hot to touch. Ambient temp perhaps 77 degrees. Is this expected and normal? Charging has worked fine for a number of cycles, but I'm nervous about premature failure due to excessive heat.
I didn't realize that 8% inefficiency (the corollary of 92% efficient) could generate this much heat. Not being trained in this area, I don't know how to calculate expected heat generation from power conversion inefficiency.
temperature
billmania avatar image billmania commented ·
I have three IP67 120V 13A chargers. Their surface temperature exceeds 140F when operating at full 13A charge current. That seems excessive to me.
What is the "normal" maximum operating temperature for this model?
Supra-Halbleiter avatar image
Supra-Halbleiter answered ·
